  • stazzy Friend
    #202767
    Good morning Boss. Pls help me make my ja nex v2 responsive. Pls. Thanks
    Could you send me via Private Message a working super user account to your backend ? and also the url for it ?
    I will have a look at it
    I checked your website
    To have it responsive you should enable the T3 Framework plugin and not the JaT3 Framework plugin also you have as default template the JAT3 version of the template instead you should switch to the ja_nex_t3 – Default
    For all the references about the T3 Version of the template take a look HERE
    stazzy Friend
    #555318
    Thanks. Sir. But How will I move from janex v2 to janex. T3 without loosing my files?
    stazzy Friend
    #555319
    Or will I install the janex t3 template and set it as default or. Pls explain?
    <em>@stazzy 453239 wrote:</em><blockquote>Or will I install the janex t3 template and set it as default or. Pls explain?</blockquote>
    You already have it installed check inside your templates and also you have the T3 framework installed
    You should follow the userguide i posted above to set your modules and new pages for your new template
    stazzy Friend
    #555321
    OK Thanks u Very much. So in general I Should set d janex t3 as default template and change all d module positions?
    <em>@stazzy 453241 wrote:</em><blockquote>OK Thanks u Very much. So in general I Should set d janex t3 as default template and change all d module positions?</blockquote>
    Yes
    Also disable the JA T3 plugin and leave enabled only the T3 Framework plugin
    stazzy Friend
    #555330
    Tanks Boss. Anytin I’ll let u know. Tanks Once again
    stazzy Friend
    #555331
    Sir i hav installed and activated the ja nex t3 and d page is nt loading pls help
    <em>@stazzy 453261 wrote:</em><blockquote>Sir i hav installed and activated the ja nex t3 and d page is nt loading pls help</blockquote>
    I cannot access your backend i receive a 404 error , what’s happened ?
    stazzy Friend
    #555385
    had issues uploading my files again wen am done i`ll let u know. Good morning.
This topic contains 12 replies, has 2 voices, and was last updated by  stazzy 10 years, 1 month ago.
