  • utehit Friend
    #203109
    I am trying to install ja-nuevo on a running joomla system 3.2.1 with ja_puresite as main template.
    Ja-nuevo meant for several micro pages.
    Ja-nuevo installalation woked first but not T3 options and theme-magic and so on.
    I installed the T3 plugin 3.2.1 and receive when trying to open ja-nuevo in template manager following error message:
    Fatal error: Cannot redeclare class T3Path in /home/www/appeleon.utehitzig.de/plugins/system/jat3/jat3/core/path.php on line 191
    Any idea if the problem is solvable?
    Ute
    the given user and pw work also for access restriction
    jooservices Friend
    #556877
    Hi there,
    Please provide your site FTP access for checking.
    Thank you,
    Viet Vu
    utehit Friend
    #556901
    Credentials removed
    thank you for looking into it.
    Ute
    chavan Friend
    #556903
    @utehit please don’t provide ftp details in thread, send it through private messages.
    jooservices Friend
    #556971
    Hi there,
    I have received your information from our staffs. And i’m checking for now.
    Thank you,
    Viet Vu
    jooservices Friend
    #556972
    Hi there
    It should be fixed on your site. Please check it.
    Thank you,
    Viet Vu
    Adam M Moderator
    #557100
    Hi @utehit,
    I’m afraid that you cannot use JA Puresite (JA t3v2 framework) & JA Nuevo (T3 framework) together since they’re using 2 different frameworks. This matter was discussed before, for example this thread.
This topic contains 7 replies, has 4 voices, and was last updated by  Adam M 10 years ago.
