November 21, 2013 at 12:57 pm #192440
i discovered the JA-K2Filter Extensions, and it seems, that this is a very useful extensions. I made the configurations which it describes in the documentation of JA-Obelisk.
The fact is, it seems not to work with Joomla 3.2.
First Issue: If you try to write in search Terms in the labels, there is very hard to do it. Because there is not very clear, where you can put the Cursor into it.
Second Issue: I use in Extrafields searchable Text delimeted with commas. If i try know, to write a name into the labelfield, K2Filter shows suddenly the whole strings of combinations. One Name is part of different K2-Items in Extrafields. It does not search only one name. it searches for the wohole string.
Example:
Sting in Extrafields:
K2-Item1: Extrafield Autor: Autor1, Autor2, Autor3, Autor4, Autor5
K2-Item2: Extrafield Autor: Autor6, Autor2, Autor7, Autor8, Autor9I want to get the Result if i search for Autor2 these two K2 Items and not only K2Item1.
Thanks a lot for your help.
Luna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
November 23, 2013 at 2:55 am #513221Hello,
I have checked your site and see that in K2 Filter Module, the label is overlayed on the input box, that’s why you can’t put cursor into it.
Go to your default template >> CSS file, find these lines:
ul.vertical-layout li label.group-label {
color: #7A7A7A
font-size: 11px;
font-weight: bold;
margin-bottom: -20px; >> remove this line
margin-left: 10px;
position: relative;
}For your second problem, I think it’s Auto suggestion feature, will show the whole phrase each time you type. You can disable this function by going to backend >> Module Manager >> Open K2 filter >> Find ‘ Auto complete’, set to No.
November 25, 2013 at 12:38 pm #513415Dear Luna garden.
thanks a lot. These settings solved the problem.
One Question. Is there a possibilty to have the labels ddescription inside the box, and when i enter the box, the description disappear? Such like in the search module.
Many Thanks
niko BellgardtLuna Garden ModeratorLuna Garden
- July 2011
November 27, 2013 at 3:12 am #513642Hi Niko Bellgardt,
<blockquote>One Question. Is there a possibilty to have the labels ddescription inside the box, and when i enter the box, the description disappear? Such like in the search module.</blockquote>
I have discussed with our dev team about your request and it will be added on next version of K2 Filter. You can track its status here: http://pm.joomlart.com/browse/JAK2FILTER-132 -
This topic contains 4 replies, has 2 voices, and was last updated by Luna Garden 11 years ago.
