  • tkfranz Friend
    #130261
    I am testing Ja Olyra template on Joomla and it’s missing Hightlight and spotlight sections. No Ja modules in Module panel. I did this on Joomla 1.0 and 1.5. Did i miss somethning during the installation? Or is it something you can add on your own and it’s not included with the template?
    tempusserbia Friend
    #256900
    You have to publish modul on user6 position, for Spotlight, then you will be able to see published modules on positions: user1, user2 and user4.
    If there are no module on position user6 then, user1, user2 and user4 will not be shown.
    Modules Published to User positions are not appearning
    tkfranz Friend
    #256987
    Ok it worked. Now The Features and Statistics are in orange and green. I don’t have Features option to choose and statistics are in white. Another issue is with the highlight section. Yours is displaying three images in a row. Mine only two and another below those Two. How to make this template look exactly like the one you’re demonstrating? Thanks
    mj1256 Friend
    #257007
    buy a membership like everyone else and download the quickstart
    tenajsa Friend
    #275723
    <em>@tempusserbia 63034 wrote:</em><blockquote>You have to publish modul on user6 position, for Spotlight, then you will be able to see published modules on positions: user1, user2 and user4.
    </blockquote>
    :confused:How? do you create user6 position. I use joomla 1.5.7 Ja Olyra and I created them in custom because I didn’t know any other way to get to the dropdown menu. What are the steps in creating the Spotlight, user1, user2, and user5. https://takeemtothebank.com.
This topic contains 5 replies, has 4 voices, and was last updated by  tenajsa 16 years, 3 months ago.
