  • staurakis Friend
    #819955
    Hello all,
    I have a problem with "Portfolio" part of JA Onepage template, where when I edited a simple headline of an article, the whole template "broke" as you can see (nooseit.com).
    More specifically, there is a line that appears whenever you edit and save an article and the second line of articles goes further down, looking quite bad.
    Is it possible to fix these issues?
    Thank you very much in advance for your help.
    Theodore
    Hi Theodore,
    You can go to file: http://www.nooseit.com/templates/ja_onepage/local/css/themes/modern/template.css
    Look for this css rule:
    .portfolio .ja-cp-main .ja-cp-group .ja-cp-item {
      color: #999 !important;
      font-weight: 300 !important;
      min-height: 280px;
    And add the min-height property like above.
    Hope this helps.
    Cheers!!!
    staurakis Friend
    #826971
    Hello Saguaros,
    everything is great concerning the big space between the blocks! Thank you very much for that.
    Is it possible however, to fix the little space on the white block bellow the picture and in between the two tittles?
    And one last thing, is it possible to change the black&white "effect" and change it to original color for the pictures?
    Thank you very much in advance for your great help.
    Regards,
    Theodore
    Hi Theodore,
    It’s grayscale image, you can follow suggestion in this topic to disable it: https://www.joomlart.com/forums/topic/disable-image-grayscale-to-color/
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 8 years, 11 months ago.
