I PM JA staff, but no response! 🙁
not sure if this will work but under the module title
instead of only
你的購物車
type
<span>你的購物車</span>
using <span>你的購物車</span> DOES NOT WORK
I tried replacing the whole template folder with the one in quickstart (even overwrite my Joomla files with quickstart), and made the exact same module and template setting as quickstart. It still does not fix the issue. this is driving me crazy…
<em>@chanton 110888 wrote:</em><blockquote>using <span>你的購物車</span> DOES NOT WORK
I tried replacing the whole template folder with the one in quickstart (even overwrite my Joomla files with quickstart), and made the exact same module and template setting as quickstart. It still does not fix the issue. this is driving me crazy…</blockquote>
I finally found out the root of this cause, which is a System – RealtyHeadTag plugin. After trun it off, all goes well.
Thanks a lot for helping.
This topic contains 19 replies, has 4 voices, and was last updated by chanton 15 years, 10 months ago.
