  • tr2media Friend
    #153713
    I made an form with joomla fabrikar and I would like to open this in an ja popup lightbox, how would I do this?
    When I publish the entire URL in the Ja popup then offcoarse I get the entire page, but I only want the single form and noheader, menu footer etc. I dont seem to be able to get this working.
    I can publish this form in an module position, so publishing a module position in the popup lightbox would do the trick. how is this done.
    Furthermore I cannot choose the Fancybox type, as the JA Ores menu will be layered on top of the lightbox and my content does not show at all.
    Browsers: FF 3.6.8 and IE 8.0
    #353418
    Dear tr2media,
    I am afraid that it is hard to get that you want,If you want only showing a single form via ja popup so in your url page I think you have to disbale all header,menu footer etc…
    If posssible you can posting your url in here we will have a closer look at the issue.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 14 years, 4 months ago.
