  • dmu Friend
    #950200
    We are using this Pro News Module and have 11 main categories, each showing 3 columns of sub-categories. Much like the demo. I keep getting fatal error messages for the memory limit, although my site is running with memory_limit set to 320M, which is huge. If I remove the number of categories being used in my JA modules, it usually makes the error go away. I’m wondering about the preferences that are stored by the News Module, for showing and hiding categories and such… it appears to save within the browser cache. With this many categories, is it possible that it is using a crazy amount of memory to process all of it?? Is there anything I can do to help?
    I don’t think it’s just this module. The Featured News Module seems to push the memory hard too. Any help is appreciated.
    dmu Friend
    #950872
    Any help??
    Ninja Lead Moderator
    #950956
    Your site is using Joomla 1.5 and I’m afraid you will not able to config it like our demo because our demo is working with Joomla 3.x version.
    Please upgrade your site to Joomla 3.x first.
    dmu Friend
    #951108
    I wait 4 days for a response… and get this. I’ve had other posts and you guys have even been on our site to assist. Of course our live site is 1.5 and that is clear. It’s also clear that it’s not using a single thing from JoomlArt. We have a new J3.6 site that we are building and that’s what we’re working on… not the 1.5 site that doesn’t even have one of your templates period. The new site (which is on the /j3 directory) runs and loads slowly with all of the JA modules… and has massive memory usage. This is what I’m looking for help on. Not display… not layout…
    Thank you.
    #951133
    You can provide me the credentials info (the URL of your site, admin login) that site via private reply. I will help you to check further
    dmu Friend
    #951185
    #951354
    I changed the setting from backend of your site: Optimize CSS and Optimize JS
    About the speed loading on your site, there are many ways to speed up your website. I have checked your site and see 60% image loading on your site, you need to optimize image on your site and you can follow the tip here
    Hope it helps
    1. Screen-Shot-2016-07-19-at-10.56.16
    dmu Friend
    #953074
    Thanks for info on how to optimize the site. I’m well aware of all of this. The site is being developed so none of that is done yet, purposely.
    I’m not asking about site load speed and such. I’m asking about how much memory seems to be used by this module. But I guess the main question that I need answered that I also originally asked is:
    Please confirm how exactly these preferences are stored so we can educate our users as to how they can best utilize those options. Thanks.
    dmu Friend
    #954581
    A reply… PLEASE?
    #954768
    @dmu: There are all steps the configuration on JA News Pro module and besides that, you can set the caching on this module. Hope my screenshots below will help you out.
    1. step_1
    2. step_2
    3. step_3
    4. caching
    dmu Friend
    #954884
    Ok, thanks for pointing out where the cache setting is in the module. I’m aware of that. My main question is yet to be answered. Here it is again:
    I’m wondering about the preferences that are stored by the News Module, for showing and hiding categories and such… it appears to save within the browser cache. Please confirm how exactly these preferences are stored so we can educate our users as to how they can best utilize those options. Thanks.
    #954954
    In this module only supports the caching as my screenshot here
    I set the configuration as your site at my end but I could not get the problem when I add or remove the categories on this module
    Below is configuration of php.ini file at my end
    memory_limit: 32M
    max_execution_time: 90
    dmu Friend
    #956182
    Okay, I’m trying again to get an answer to this question. Forget the memory issues… forget cache / speed issues. Just answer the simple question above please. WHERE ARE THE PREFERENCES STORED?? We just want to make it clear to our users so they know how to best utilize the feature. Is it unique to their browser? Or stored in site cache? Any details are appreciated.
    #956357
    You can find and see T3 cache and modules from both folders
    cache
    t3-assets
This topic contains 14 replies, has 2 voices, and was last updated by  Ninja Lead 8 years, 4 months ago.
