  • londee Friend
    #173707
    hello all,
    i’m turning a little bit crazy. my problem is:” is there a way (workflow) to make purity II j1.7 header and footer rounded corners?”
    i’ve tried to as in old t3 and purity II j 1.5 as showed in figure but it did not work…
    example here: http://wiki.joomlart.com/wiki/File:T3-how-to-the%3Dnew-header.jpg
    i’m sure that flexibility of t3 v2 make it possible…
    may someone could help me?
    thanks
    an :-[ user
    swissa Friend
    #437610
    couple of places to try looking. On my learning list 😉
    1. The wiki! http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides – Look for the ‘block attributes’ and it gives you an idea of the block styles.
    2. http://wiki.joomlart.com/wiki/JA_T3_Framework_2/FAQs#Styling_custom_block_styles
    e.g.
    Block style
    Expression: <block name=”top” style=”JAxhtml” …>
    Purpose: this parameter sets a module style for all modules inside a block. These styles are defined in the modules.php located in theyour_site/plugins/system/jat3/base-themes/default/html folder, so this way Joomla! can understand how to show the content of the modules. The styles list is:
    • no style – the default block setting with no block style defined, only provide support for module class suffixes;
    • raw – provides a blank design for modules, no div, no classes;
    • xhtml – mostly used for macro blocks like header, middle, footer;
    • JAxhtml – provides a clean design for modules;
    • JArounded – provides support for rounded corners design for modules.
    I hope that helps.
This topic contains 2 replies, has 2 voices, and was last updated by  swissa 12 years, 9 months ago.
