  • njonow Friend
    #148282
    Seems that the template is not compatible with IE 8. It has worked fine with IE 7, Firefox etc, but when I upgraded to IE 8, it doesn’t look very good.
    http://www.sunyatsenhawaii.org/
    Anyone else had this problem? Any suggested resolutions?
    Hello
    Now, here is the solution for you
    Please open the file: templates/ja_pyrite/index.php and try to find codes at line 52
    <style type=”text/css”>
    .clearfix {display: inline-block;}
    </style>
    Replace:
    </style>
    .clearfix {display: block;}
    </style>
    Hello
    </style>
    Replace:
    </style>
    </style>
    adminet Friend
    #354165
    I made this change to the index.php file, and it moved it over from the far left, but it still isn’t centering the text. I’m using text instead of image for the logo.
    <em>@adminet 192232 wrote:</em><blockquote>I made this change to the index.php file, and it moved it over from the far left, but it still isn’t centering the text. I’m using text instead of image for the logo.</blockquote>
    Please provide me the link to your site, i would like to have a closer look on the issue
This topic contains 5 replies, has 3 voices, and was last updated by  Saguaros 14 years, 3 months ago.
