mainstay Friend
mainstay
- March 2009
March 6, 2010 at 7:35 pm #149261I successfully installed JA Quartz for a Joomla 1.0 site. I downloaded the correct template version. Once installed I set it as the default template and the page on the web shows blank. I went to look at the html and noticed that the html files were completely blank. It would also not allow me to view/edit the css. When I looked at the original files that were zipped, I noted that the index.php and index.html files had no code in them. I don’t know if this is also causing problems with not being able to view the css file from the joomla control panel. Thanks for your assistance.
histeriks Friendhisteriks
- December 2009
- 114 times in 87 posts
March 6, 2010 at 8:19 pm #335132mainstay;168043I successfully installed JA Quartz for a Joomla 1.0 site. I downloaded the correct template version. Once installed I set it as the default template and the page on the web shows blank. I went to look at the html and noticed that the html files were completely blank. It would also not allow me to view/edit the css. When I looked at the original files that were zipped, I noted that the index.php and index.html files had no code in them. I don’t know if this is also causing problems with not being able to view the css file from the joomla control panel. Thanks for your assistance.
Hi mainstay,
did you try to download the package again and reinstall?
mainstay Friendmainstay
- March 2009
- December 2009
March 6, 2010 at 10:08 pm #335141mainstay;168050Yes I did and the two files are still blank with no code. I just did it again to check and it’s the same.
Yes, i see now, thank you very much mainstay, staff is notified and the situation will be resolved very quickly.
- March 2009
March 9, 2010 at 7:02 pm #335518Thanks. I’m still waiting for the updated template to be uploaded so I can download. Do you have any idea how long it takes for them to handle this?
- 1334 times in 848 posts
- March 2009
March 11, 2010 at 7:46 pm #335854Thanks for working to get the correct template uploaded, however, I tried to install with the new files and received two error messages. Bad file error and cannot find install file.
This topic contains 8 replies, has 3 voices, and was last updated by mainstay 14 years, 9 months ago.
