  • mombo Friend
    #143226
    I have by the JA Raite Template a problem, I can only 1 images insert in the frontpage, if I insert a second or third images then the picture not to show on the frontpage. I see only the picture after the setting Read more.
    Why I can change the CSS seeting?
    @mombo
    Anonymous Moderator
    #313325
    Hi mombo
    it is very strangle. I could not find this issue in our template.
    Could you please send me your live url, admin account via PM so that i could have a closer look on the issue?
    mombo Friend
    #313603
    The access I send you yesterday by private massage, the css problem should to be in template.css. Because if I deactivate /css/template.css then the second picture show correct but without design….
    Anonymous Moderator
    #315494
    Hi mombo
    Thank you for your PM but i could not access your administator with your account which you sent.
    Please kindly check again.
This topic contains 4 replies, has 2 voices, and was last updated by Anonymous 15 years, 4 months ago.
