  • mordecai Friend
    #126433
    Hello! My JA RSGallery2 Slider doesn’t show up properly. for example, the scrolling menu at the bottom turns up as a static vertical row of thumbnails. and the the slideshow doesn’t work either.
    you can see how it looks like over here.
    Please help!
    1. Picture-2
    #241653
    Plz say: version joomla ? you install quickstart or only install template and extensions?
    #241654
    Or you can try:
    – Enable your GD2 Libraries in you php. – If your site hadn’t import mootools.v1.1 so to run this module you have to remove all comment characters in code On line 39 in mod_ja_slidegallery.php file to import mootools v1.1
    mordecai Friend
    #241701
    <em>@nguoiabcd 43743 wrote:</em><blockquote>Plz say: version joomla ? you install quickstart or only install template and extensions?</blockquote>
    I installed only the template and extensions. I’m using Joomla version 1.5 with Legacy 1.0 enabled. I should install Quickstart?
    CptDecker Friend
    #241760
    <blockquote>On line 39 in mod_ja_slidegallery.php file </blockquote>
    What is this file? When I d/l the packages, I see mod_ja_rsslide.php but I have nothing called like what you mention. What extension package is it from?
    My problem, running mod_ja_rsslide is that no thumbnails show up at all. I get the two arrows, but nothing in between. I see the thumbs in the /images/rsgallery/thumb/ folder
    Running J 1.0.12.
    Any suggestions?
    #241773
    HI mordecai.
    You should install quickstart, so you will have a full site like demo.
This topic contains 6 replies, has 3 voices, and was last updated by  Sherlock 16 years, 9 months ago.
