webmestrejoomla Friend
webmestrejoomla
- May 2012
May 29, 2012 at 10:40 pm #177669Hello
I have added a JA side news component on the home page, but even if I set the language to “french”, the “more details” link still being displayed in english. How can can I solve this issue?
Thanks in advance for your help.pavit Moderatorpavit
webmestrejoomla Friendwebmestrejoomla
- May 2012
June 5, 2012 at 1:24 pm #456084Hi Pavit,
thank you for your reply but it seems not to work.
I have done what you suggested but this seems only to have an impact on the administrator side, not the site side.
I want to change the “More details” link in frontend because my side is in french, not in english.
How can I do that?Sherlock FriendSherlock
- 2478 times in 2162 posts
June 6, 2012 at 2:11 am #456183<em>@webmestrejoomla 323644 wrote:</em><blockquote>Hi Pavit,
How can I do that?</blockquote>I wonder why it does not work, you can pm me your FTP info , I will have further checking for you.
- May 2012
June 6, 2012 at 10:46 am #456283FTP info PM.
I think that the problem is that the exact string “More details” is not present in the en-GB.mod_jasidenews.ini file, so if I translate the sources present on that file it wouldn’t make a difference. The sources present on that file correspond to the back-end administration of the module, not to the front-end displayed text.
I am missing something?Sherlock FriendSherlock
June 7, 2012 at 2:54 am #456371<em>@webmestrejoomla 323874 wrote:</em><blockquote>FTP info PM.
I am missing something?</blockquote>I do not see a file name language/fr-FR/fr-FR.mod_jasidenews.ini, have not you followed pavit instruction ? I put the file there for you, you now can open that file language/fr-FR/fr-FR.mod_jasidenews.ini look for the translated text
MORE_DETAIL=”More detail”
You can change the text there to see if it work -
This topic contains 6 replies, has 3 voices, and was last updated by Sherlock 12 years, 7 months ago.
