  • panospap Friend
    #204744
    I used Sidenews Module with Tabs Top Plugin and it works fine, but there are some blank positions under the tab, as you can see in my attachment.
    Do you have any suggestions?
    Thank you in advance
    1. prtnew
    chavan Friend
    #563411
    add this code to custom.css
    .ja-tab-subcontent .ja-slidenews-item{
    min-height: 270px;
    panospap Friend
    #563417
    I added this code, but nothing happened
    chavan Friend
    #563488
    I have added the code to the top of the custom.css and your alignment is fixed now.
    your custom.css has some incorrect css code. please fix those.
This topic contains 4 replies, has 2 voices, and was last updated by  chavan 9 years, 8 months ago.
