  • meioaereo Friend
    #150324
    When I am using IE the description for each slide appears in a wrong orderr or it takes some time to change.
    For example: When the second slide appears, it still showing the description for the first image and the same happens for the third and fourth slide. It doesn`t happen with firefox.
    Here is the link http://www.dfall.com.br/escola
    Can someone come up with a fix?
    Dear meioaereo!
    This is a bug from old version, please kindly re-dowload the ja slideshow 2 module from here : http://www.joomlart.com/forums/downloads.php?do=cat&id=159
    and try to upgrade for yours
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 8 months ago.
