  • graceful Friend
    #157788
    Installed ZEOLITE II on existing Joomla site, but when I enabled JA-SLIDESHOW module, the slidedshow image shows behind the main body modules.
    Your assistance is greatly appreciated.
    – J
    graceful Friend
    #368207
    anyone? just trying to sort this out asap.
    Ninja Lead Moderator
    #368254
    hi djproaudio,
    please provide your site url if its a live site, if not can you please upload it to a temporary host?
    graceful Friend
    #368282
    Here is the site
    #368285
    You need a fix on CSS, open modules/mod_jaslideshow/ja_slideshow/ja.slideshow.css line 29, change #ja-slideshow-case in to this:
    #ja-slideshow-case {
    left: 0;
    top: 0;
    graceful Friend
    #368311
    Thanks. Worked great. Lastly, having an issue with the Linking of the images.
    Here is what I put in the Description Parameter section:
    sl-1.jpg:caption=&url=http://mywebsite.com/page
    I only have 1 image in the slideshow directory for testing purposes. I set the SHOW DESCRIPTION parameter to YES. is there something else I am missing?
    Thanks again.
    #368399
    dear djproaudio,
    this is due to a bug, you can try to remove the absolute path of the urls
    sl-1.jpg:caption=&url=/rent/rental-products/music-recording/basic-mix-package
    it will work fine.
    thuanlq Friend
    #369323
    Hi @djproaudio,
    Youn can try to add description as this format:
    This is description for header 1
    This is description for header 2
This topic contains 8 replies, has 3 voices, and was last updated by  thuanlq 13 years, 10 months ago.
