  • cybernun Friend
    #179212
    Sorry to repeat this Forum entry but am not getting this solved and could find no way to request Administration Help other than to start a new thread and ask for Admin Help in the available drop down. Admin – you have log in details but if anyone out there thinks they can answer this, please do jump in.
    Slideshow Lite works fine but the links are not.
    It makse no difference if I use full path of just article url.When you click the slideshow image, the article shows up at the BOTTOM of the Home page. The link will not take you to the actual ARTICLE PAGE.
    I really need this solved and am hoping soon. I believe this issue has to do with the way the HOME menu item is set up (I’m not using K2). HOME is set to “featured articles”…hmmm…
    HELP much appreciated! :((:((:((:((:((
    cybernun Friend
    #461338
    ANOTHER DUH MOMENT.
    I should know better.
    Home page was set to “Featured Articles” so OF COURSE it would show linked articles (even in the slideshow apparently) there instead of going to actual article. I have adjusted and now the links work just fine.
    Sorry for the alarms but perhaps this will help someone else. :):)
This topic contains 2 replies, has 1 voice, and was last updated by  cybernun 12 years, 5 months ago.
