Viewing 15 posts - 1 through 15 (of 19 total)
  • dattard1 Friend
    #206613
    Hi, am using JA SlideSow to create a bit of a slideshow on the frontpage: http://www.dart-creations.com
    Th text and titles all seem garbled – and also need to set a good width and height which works well and stays responsive…
    I can’t access your site, pls check my PM
    dattard1 Friend
    #571816
    Replied in PM
    dattard1 Friend
    #736862
    Replied in PM
    dattard1 Friend
    #572024
    It WAS already configured in that way – still looks horrible
    dattard1 Friend
    #737069
    You can take a look again at the position, we assign this slideshow to ‘home-30’ position which is wider than the current position you’re assign it to.
    The width is not large enough while the text is big and it causes the slideshow not look nice.
    dattard1 Friend
    #572165
    Ok – i want to set it up as in Home-10 in the following image then
    http://static.joomlart.com/images/userguide/ja_templates/ja_magz/ja_magz_position.png
    How would I need to set it up?
    You will need to customize the style for this slideshow.
    Just open the css file: root/templates/ja_magz (your default template)/css/custom.css – this file will keep your custom css code.
    and add rule for elements of slideshow:
    .maskDesc .ja-slide-desc {
    color: #fff;
    font-family: 'novecento_wide_bookbold',sans-serif;
    font-size: 35px;
    font-weight: 700;
    line-height: 1.3;
    text-transform: uppercase;
    text-align: center;
    .maskDesc .ja-slide-desc a span {
    background: #1ea1fc;
    color: #fff;
    font-weight: bolder;
    padding: 10px;
    opacity: 0.9;
    filter: alpha(opacity=90);
    and you can change the value for above property (font/color/etc…) to the value which suits your need.
    In case, it doesn’t work, you can illustrate the modification you wish via screenshots, I will give further suggestion.
    color: #fff;
    font-size: 35px;
    font-weight: 700;
    line-height: 1.3;
    text-align: center;
    color: #fff;
    padding: 10px;
    opacity: 0.9;
    dattard1 Friend
    #572918
    I put these settings in my custom.css but there was absolutely no change to the slideshow … I could play around a bit more once I get the css to apply well, but I’m not sure this is the correct css to apply?
    dattard1 Friend
    #737952
    In case it doesn’t work, you can send me screenshot illustrating how you want to customise and PM me the FTP account of your site, I will check it for you.
This topic contains 19 replies, has 3 voices, and was last updated by  Ninja Lead 9 years, 5 months ago.
