kurdapya Friend
kurdapya
- October 2008
- 2 times in 1 posts
March 6, 2009 at 1:21 pm #138846There seems to be a problem when i enable the Description text.. it’s blurred and unreadable.. can u please check..
i have attached the page. Will pm the url if necessary.
kurdapya Friendkurdapya
- October 2008
March 7, 2009 at 7:55 am #294752anybody home???
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
March 7, 2009 at 11:26 am #294769kurdapya;116233anybody home???
all home but no url cant define what the problem is also it helps if you tell us what browsers you’ve checked it in etc
- October 2008
March 7, 2009 at 11:57 am #294770Well it’s quite visible from the image file i have attached.. but here is the link anyway.. starsinstyle.com.
It’s also much much better to have reply and be asked about more information needed to solve the problem..Anyhow.. thank you for your reply… at least u did reply!
Consider this problem solved: Description will only show up properly on IE, Mozilla but not Chrome…
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by kurdapya 15 years, 9 months ago.
JA Slideshow, Position: ja-slideshow txt problem
