  • Fokstrot Friend
    #160881
    I updated to the 2-14-2011 version of JA Slideshow and now there is a problem with article description.
    Problem: Description shows with 0 opacity, but settings are set at 1 opacity.
    Pictures:
    huypl Friend
    #379325
    Hi novajugo,
    I had visited your website but found no problems with JA Slideshow. Please check it again.
    thuanlq Friend
    #379774
    Dear Matthew B,
    Please check your site again, the text color of slide’s description is “White”. Please change it to “Black” or any dark color, to change text color please do as following:
    – Open the file “template.css” in the folder “templates/ja_rave/css/”, then add this style in to end of file content:
    .moduletable_highlight .ja-slide-desc {
    color: #000000;
    Regards,
    Fokstrot Friend
    #380111
    That worked. Thank you. Just for your info, I never changed the description color prior to installing the 1.0.4 version.
    Something in the 1.0.4 version caused it to become white.
This topic contains 4 replies, has 3 voices, and was last updated by  Fokstrot 13 years, 10 months ago.
