  • salvol Friend
    #194246
    Hi Guys,
    I am trying Ja Music template on a website and I am having problems. I try to configure the module and it just doesn’t let me save the setting. The only things that works is the CLOSE button.
    Any suggestion?
    Thanks a lot in advance
    The provider is Aruba
    Hi there,
    This issue often due to the permission of your site’s file/folder in your server, it may be unwritable. If you use an editor like Firebug in Firefox browser, when you click Save button > check Error tab of Firebug, you will see which file caused this issue.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 10 years, 10 months ago.
