  • Ing. Ervin Zatko EASY Friend
    #192392
    A work on a page based on a template JA MUZIC (Joomla 2.5). Today I upgrade Ja SlideShow module from 2.6.2 to 2.6.6.
    After upgrade I have these problem:
    – when slideshow go to the end and start again from the first item, after all videos is blank (white page)
    The problem is in file helpers/helper.php.
    Please send me a solution ASAP.
    Thanx
    1. jaslideshow
    Ninja Lead Moderator
    #512810
    Please pm me URL and admin login of your site. I shall help you to check this problem
    anhsangsankhau Friend
    #514757
    Hey, me too!! I also encountered this problem :(( :(( Version 2.5 need help~
    I install the quickstart package J2.5 and I use a localhost. Plz!!
    btw, J3.x is ok.
    #514909
    @easypc and @anhsangsankhau: Sorry for the problem you’re facing. This happens when JA Slideshow module runs with iframe of video data. Here is solution:
    Open modules/mod_jaslideshow/assets/script/script.js file
    + Line 316->318
    From
    if(typeOf(vars.iframeItems[vars.curIdx]) != 'null'){
    vars.iframeItems[vars.curIdx].removeProperty('src').setProperty('src',vars.iframeItems[vars.curIdx].getProperty('data-src'));
    Change to
    var datasrc = vars.iframeItems[vars.curIdx].getProperty('data-src');
    vars.iframeItems[vars.curIdx].setProperties({
    'src':datasrc,
    'alt':datasrc
    + Line 327->329
    From
    Change to
    'src':datasrc,
    'alt':datasrc
    Or you can download my attached file and copy it into modules/mod_jaslideshow/assets/script/script.js file.
    Don’t forget back-up old file before making any change
    1. script.zip
    #517348
    Today I try upgrade to the new version 2.6.8. And here is again these problem !!!
    Ervin
    #517481
    Hi Ervin,
    I have quickly checked and see that my solution above still works for the JA Slideshow module version 2.6.8, see the screenshot for reference:
    Kindly check again.
    1. script
    #517662
    Dont work for me. See: test.easypc.sk
    Ervin
    #517727
    Hi Ervin,
    Please send me URL of your site, admin and FTP credentials via private message. I need to have a closer look into your site to investigate further.
    jp Friend
    #528825
    Hi Ninja
    I had the same problem after updating
    I did the changes as you suggested, the only problem is the thumbnails is not working now?
    http://www.christinme-international.com
    #528885
    @jptromp: Have you tried to update the latest version here ?
    jp Friend
    #529852
    Hi Ninja
    Yes i have the latest version of JA Slideshow Module
    #529927
    <em>@jptromp 420404 wrote:</em><blockquote>Hi Ninja
    Yes i have the latest version of JA Slideshow Module</blockquote>
    Please send me via Private message your admin and FTP credentials, I will help to check further.
    jp Friend
    #531331
    Seems like its fix now,
    I upgraded everything except Joomla itself 🙂 rookie mistake
    Everything is working now thank you
This topic contains 13 replies, has 4 voices, and was last updated by  jp 10 years, 8 months ago.
