  • djtaylor Friend
    #172357
    Hi happy new year everyone
    i love the JA Slideshows but because of performance issues i do not use as it takes way to long to load up
    but on the demo templates its instant? how can we get it to load up the same speed as the demos?
    i have tried everything i can think of lowering the picture quality and size and ive noticed this on every template i have used
    is there any way to speed things up it should be the first thing to show up as its a big part of the template and not have to wait from 3-10 secs to load?
    Manos Moderator
    #432403
    Did you try to use cache for that module ? I assume this will speed up the loading time.
    djtaylor Friend
    #432503
    how do you enable cache for the module and what seetings should i put it on?
    thanks for your reply
    Manos Moderator
    #432807
    Please tell me the exact version of the module you are using so i can give you more info on how to enable cache etc.
    djtaylor Friend
    #432811
    hi thanks im using Joomla! 1.7. ja ironis slideshow
    Manos Moderator
    #433249
    In advanced mode (ja slideshow) you can enable cache and set the amount of time you want those files to be kept.
    See my image to help you better.
    Please let me know if that solves your problem.
    1. ja-slideshow
    djtaylor Friend
    #433255
    hi thanks what does cache time mean is it the lower the number the quicker it will load, or higher?
    Manos Moderator
    #433319
    Cache time is the time that your files will be recreated or stay the same, the lower the number the more frequently your files will be recreated so any new file you probably have uploaded will be included on your slideshow.
This topic contains 8 replies, has 2 voices, and was last updated by  Manos 12 years, 10 months ago.
