Viewing 15 posts - 1 through 15 (of 18 total)
  • inforpedros Friend
    #134955
    Hi.
    In JA Sanidine II template, using JA Slideshow the Thumbs go out from the main limited area.
    Even in your demo does the same thing.
    How can i correct this issue?
    Thanks in advance for your support
    1. image
    #277834
    Can you give us your live URL?
    Because I tested demo on all browsers and it works
    inforpedros Friend
    #277897
    <em>@nguoiabcd 89079 wrote:</em><blockquote>Can you give us your live URL?
    Because I tested demo on all browsers and it works</blockquote>
    Here is the url http://www.inforpedros.pt
    effektlabor Friend
    #277904
    Hi, it works with Firefox but check it out with Internet Explorer (7.0.5730). The thumbs of JA Slideshow break out of the main area (the last of the 4 pictures breaks the bottom border of the JA Slideshow frame). You can see it at the picture inforpedros attached and it even happens at the Joomlart demo site.
    best regards!
    #277978
    please change ja.slideshow.css (line 43)
    #ja-slidebar ul li {
    background:transparent none repeat scroll 0 0;
    display:block;
    margin:0 0 10px;
    padding:0;
    width:100px;
    Change to
    display:block;
    margin:0 ;
    padding:0;
    width:100px;
    inforpedros Friend
    #278031
    Perfect.
    Thanks nguoiabcd.
    starlet Friend
    #278066
    I just tried this same code to correct my site.
    I am having the same trouble but the fix in the code didnt seem to fix it.
    take a look and tell me what is wrong if you have the time, http://www.maim.cc/forum1
    #278125
    i have checked your site and saw that you didn’t change as I said
    i still saw those lines as original :ja.slideshow.css (line 43)
    display:block;
    margin:0 0 10px;
    padding:0;
    width:100px;
    Please change as I said above
    starlet Friend
    #278157
    Sorry i changed it back as it didnt seem to change. I have changed again to
    display:block;
    margin:0 ;
    padding:0;
    width:100px;
    please can you check again http://www.maim.cc/forum1
    effektlabor Friend
    #278159
    Still the old code… are you sure you saved the ja.slideshow.css correct? Do you have the rights to write files on your ftp?
    effektlabor Friend
    #278160
    “Sorry i changed it back as it didnt seem to change.”
    —> Did you clear your browser cache?
    The code nguoiabcd recommended works. I had the same problem!
    starlet Friend
    #278163
    Strange. I am using webshell. I downloaded the file to my desktop opened it and edited it using dreamweaver. Changed the code and then uploaded again. When i download and check the code at my end it has been changed.
    Could it be that i need to change the CHMod settings for this file? It is currently set to 644
    Just to be sure im am editing the corrrect file, the path im using is modules/mod_jaslideshow/ja_slideshow/ja.slideshow.css
    effektlabor Friend
    #278164
    Have you cleared your browser cache (Internet Explorer) and checked it again?
    effektlabor Friend
    #278166
    NOOO! 😉
    The correct path is /templates/ja_sanidineii_light/css/ja.slideshow.css
    starlet Friend
    #278167
    Ah perfect, thankyou 😀
    Silly me, i never thought that there may have been more than one css file for slideshow.
    Its tough being a website noob 😮
This topic contains 18 replies, has 4 voices, and was last updated by  starlet 16 years, 1 month ago.
