  • leonike Friend
    #151764
    Dear all,
    when using the slideshow module with Zeolite the banner is eating into the main container below . Please see the thread:
    http://www.joomlart.com/forums/topic/problem-with-ja-slideshow-and-zeolite-2-template/
    Therefore I am using module JA Slideshow2 (Ver. 2.0.3). I have assigned the Ja Slideshow2 module only for the start page and it works well!
    But during the checkout procedure the JA Slideshow2 appears unrequested, please see attachment
    Please advise how can I avoid this.
    Thanks!
    Best regards
    leonike
    1. Unbenannt-1
    leonike Friend
    #346989
    any idea?
    I would like to disable module slideshow and fp-vm position during customer checkout. It´s really a zeolite template issue.
    Dear leonike!
    As the modules auto disable and enable based on the menu asigment which inside the configuration of module,
    purpose that your site has the “Shop” menu related with the vituemart component.
    If you asigned the module on the “Shop” menu, the module display all pages related with the Shop menu. to control displaying modules for some pages of virtue mart, you must to customize code
    Good luck
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 14 years, 6 months ago.
