  • andersonannem Friend
    #150395
    Hello.
    I’ve applied several different changes that I read in these forums, but have not successfully been able to change how articles are showing up in the forum. I hope you can help.
    1. Why does the text in the slider look so awful in IE8. It looks like a .gif looks when you don’t apply the right matte color around the image when you create the .gif for the web.
    2. How can I set it up to NOT show ANY images when an article is displayed. I tried having the images only after a readme break and that didn’t do it. I also applied the following to the default_articles.php file
    “// parse image in the article’s content.
    $helper->parseImages( $item, $params );
    $list[$k]->introtext =strip_tags( $item->introtext); ”
    and this did not fix/change anything either. I saw the thread about removing the black behind the image, but that didn’t work.
    I’d rather live without the images, as they show up with the text over-writing them, which isn’t very nice to look at.
    3. I tried to include a Link in the portion of the text that appears in the slideshow, but when I applied some styling to the link (a different color) the text showed up super big and I had to remove it.
    Thank you.
    Anne
    Dear Anne!
    <blockquote>1. Why does the text in the slider look so awful in IE8. It looks like a .gif looks when you don’t apply the right matte color around the image when you create the .gif for the web.</blockquote>
    Can you please give me the link to your site . thanks
    <blockquote>
    </blockquote>
    Please fix this issue as folllowing: please open the file: templatesja_oreshtmlmod_jaslideshow2default_articles.php and find codes at line 12:
    [PHP] <?php echo $helper->renderImage ($item->title, $item->mainImage, $params, $mainWidth, $mainHeight );?>[/PHP]
    please remove them to disable image in the slideshow.
    <blockquote>
    </blockquote>
    Please explain the issue in detail and give me the snapshort on the issue, i would like to have a closer look about this
    #340792
    Thank you Tienhc.
    Here is the URL: http://www.drumandtrumpet.com
    However, I had to unpublish the jaslideshow2 module and I have replaced it with another type of slideshow.
    I really like this template and may be using the jaslideshow2 module on another site. I will use your suggestion above to answer my question #2. If I continue to have these problems, I will probably have to repost or maybe I’ll find the answers I need from another thread.
    Thank you for the time it took for you to answer this for me.
    Your site looks nice with new slideshow 🙂
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 14 years, 7 months ago.
