test melih
 melih
  • dmeimaris Friend
    #681530
    Hi, I have a problem with my JA Slideshow. I have enabled videos and autoplay but the autoplay never stops so if a youTube video is started the slide after a while moves to the next one.
    Is there any solution/suggestion?
    I got your point but if you use video in slide, it’s best to not use autoplay option, as its name, it will automatically switch to another slide after a configured period of time.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 9 years, 5 months ago.
