norchris Friend
norchris
- December 2010
- 3 times in 1 posts
April 27, 2016 at 7:22 am #923314Hi π
Having a hard time making things work and decided: I need your help!
THEME MAGIC This has worked wonderfully before, but not now. I get these error messages:
**FileError: ‘/extras/com_easyblog.less’ wasn’t found (404) in template.less on line 360, column 41:
359// EasyBlog Styles 360@import "/extras/com_easyblog.less";**
This results in that I cannot see changes/preview – and there are probably larger errors on the page.
JA SLIDESHOW LITE Maybe the errors have something to do with the problems I have with JA Slideshow Lite. There are similar problems like described here: https://www.joomlart.com/forums/topic/ja-slideshow-not-showing-images-if-the-default-folder-is-changed/
But, now, when I gave up, all modules on front page was enlarged – so something is in the error here.
Maybe you could take a look inside?
Thank you!
Norchris
Saguaros ModeratorSaguaros
April 28, 2016 at 4:14 pm #924045Hi Norchris,
Kindly check the less files on your site, one of them is importing com_easyblog.less file while you’re not using EasyBlog, right?
Please search for it and remove the import query
For the slideshow, which image folder you want to change to? You can also update ftp account so I will have a closer look.
norchris Friendnorchris
- December 2010
April 28, 2016 at 8:53 pm #924158Hi and thank you!
(Sorry for placing these posts here. The installation is JA Sugite… Maybe you can move it to the right place. )
I did a clean quickstart installation a couple of days ago and this error appeared from the very beginning. I installed Sugite and upgraded to 3.5 and everything went wrong. So, I uninstalled and installed an updated Sugite quick start package. Maybe some errors came in this package and that more people will experience the same?
In ThemeMagic it looks really messed up. For another site, I work with Nuevo and nothing like this happens. It might be something with the files from you?
Norchris
April 29, 2016 at 6:58 am #924287It’s weird, I open the ThemeMagic via backend of your site but see no error: http://prntscr.com/ay733t
P/s: I also move this topic to JA Sugite forum.
etna34 Friendetna34
- 5 times in 4 posts
May 4, 2016 at 12:22 pm #926630Hi
I had the same problem, but follow this:I opened /less/template.less and at the last line I changed:
// EasyBlog Styles
to
// EasyBlog Styles
@import "extras/com_easyblog.less";
Then the error gone.It is in my post here:
https://www.joomlart.com/forums/topic/thememagic-fileerror-extrascom_easyblog-less-wasnt-found-404/Hope that will help
REgards
May 5, 2016 at 3:05 am #926881You can send me the login credentials of your site: Admin & FTP account so I will have a look.
- December 2010
May 10, 2016 at 7:46 am #928818Itβs weird, I open the ThemeMagic via backend of your site but see no error: http://prntscr.com/ay733t
Yes, but when you choose the theme Scanteamblue things mess up… Please take a look π
Norchris
- December 2010
May 11, 2016 at 7:38 am #929299Hello again!
etna34 helped out to remove an extra "/" which messed things up.
But, I struggle a lot with JA Slideshow Lite. Spent hours……
Could you take a look, please? The whole front page messes up and no pictures is shown.
Will give you logon and FTP-access in a private reply.
Thanks,
Norchris
- December 2010
May 11, 2016 at 7:41 am #929302This reply has been marked as private.norchris Friendnorchris
- December 2010
May 11, 2016 at 11:14 am #929388You can send me the login credentials of your site: Admin & FTP account so I will have a look.
Sent!
Thank you!
Norchris
May 13, 2016 at 1:31 am #930141Hi Norchris,
I check the ThemeMagic on your site but it works: http://prntscr.com/b3en8x
I don’t see error there
- December 2010
May 13, 2016 at 8:02 am #930257Hello and thank you!
When I started this thread, I was unsure of what the problem was – ThemeMagic or JA Slideshow Lite. Turned out that there was an error with a slash which I removed. Still, the problem is not solved JA Slideshow Lite works strangely.
Enclosed, screen dumps from three browsers. None of them showing pictures and all of them very strange.
- Saguaros Moderator
May 16, 2016 at 3:02 am #930923I changed the slide type to ‘custom’ in configuration of JA Slideshow Lite and it’s showing images now.
I also see that in this file: http://scanteam.viis.no/templates/ja_sugite/local/css/themes/scanteamblueweb/mod_jaslideshowlite.css
.ja-ss-item { display: block; float: left; margin: 0; overflow: hidden; position: absolute; right: 0; left: 0; width: 100%; min-height: 549px; z-index: 1; backface-visibility: hidden; -moz-backface-visibility: hidden; -webkit-backface-visibility: hidden; }
Then change the ‘min-height’ property to your desired value.
- December 2010
May 18, 2016 at 6:29 pm #932063Hi and thank you!
No, that does not solve this. The error is probably connected to JA Slideshow Lite.
I kept the original Slideshow module pretty much unchanged. Now, I unpublished the module copy I have been using and published the original. The module height became correct, although there are still errors when it comes to publishing pictures.
The problems re-appear when I do changes with the JA Slideshow Lite-module. Please try! Please help!
And, I do not want to use "custom" style but something which is easier to handle.
Regards,
Norchris
AuthorPostsViewing 15 posts - 1 through 15 (of 15 total)This topic contains 14 replies, has 3 voices, and was last updated by Saguaros 8 years, 7 months ago.
