  • magtaf Friend
    #163693
    I have an issue with the template JA Social which is not triggering the Joomla Plugin Funtions in the mass-content-top position.
    This is what I sent to ACYmailing:
    I am using the loadposition commange in an article to show the signup to a newsletter. But it will on work in the mainbody of the site. I am trying to load it in the mass-content-top postion and it will not work.
    This is the template I am using so you can see the positions.
    http://www.joomlart.com/static/guides/layout/?ja_social
    Any suggestions what I can do?:-[
    This is the response from ACYMailing:
    I guess the mass-content-top position does not trigger the Joomla plugin system and so the tag is not replaced by the AcyMailing subscription module?
    I’m afraid I don’t know how this joomlart template works and you should probably ask this question to joomlart.
    I am coming here for some support to see what can be done.
    now, you access the template configuration then disable the cache option, then checking this issue again. If the issue could not resolve, please provide the Super Administrator account via your ticket ID MSJ-234-42344
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 13 years, 7 months ago.
