  • sarah… Friend
    #979418
    Hello. Since a few days i can’t assign a background image in my template.
    Can you help me?
    Hi there
    Could you post a screenshot of which part of template you want to have a background image ?
    sarah… Friend
    #979422
    I assign in backend a backround image, but it don’t show it in frontend.
    1. Bildschirmfoto-2016-10-23-um-19.17.23
    Hi there
    Could you post here a link to your website and a super user account to it ? i will have a look at it directly
    You can answer to this post flagging below square box "set as private reply"
    sarah… Friend
    #979427
    As you can see from documentation page HERE Template style assigned to the default page, should use the features-intro layout type.
    Your template style assigned to your "start" menu item is using the "default" layout
    sarah… Friend
    #979434
    i don’t know why … that is the trouble, if i change to features intro i see a blank page… 🙁
    i don’t know why … that is the trouble, if i change to features intro i see a blank page… ?
    Enabling error reporting on your menu item using "features-intro" layout it shows a memory limit problem ( look at image )
    You should increase memory available for your website,. try to ask to your hosting provider to do it for you
    1. Screenshot-at-ott-23-21-34-59
    sarah… Friend
    #979469
    I set the memory size higher, but same problems.
    And also the background image works on my dev page with less memory size. ?
    I still can see your memory error problem on the website , to look at it enable from global configuration -> Server Tab the error reporting feature to maximum and then refresh home with assigned "features-intro" layout to it , you will see error come on the page.
    You should ask to your hosting provider to take a look at it
    1. Screenshot-at-ott-24-12-52-54
    sarah… Friend
    #980111
    Hello pavit. My hoster gave me the DOUBLE memory size. That should be more than enough… But same trouble… Features-Intro doesn’t work again. All other standard templates working fine. Thanks for your help.
    Ninja Lead Moderator
    #980542
    The template style on your site is setting with default style by default but backgroundimage only works with features-intro and landing layouts: http://prntscr.com/cz3u6w and you can see it from both files
    templates/ja_social_ii/tpls/blocks/features-intro.php
    templates/ja_social_ii/tpls/blocks/landing.php
    sarah… Friend
    #981430
    Hello Ninja Lead, i know that, but if i change to features intro, i have a blank page in frontend. That is the trouble. 🙁
    sarah… Friend
    #981643
    No support 🙁
    #981963
    What did you change on your site? Let me know the details have been changed on your site.
    Besides that, send me the credentials info: URL, admin login and FTP account. I will help you out
This topic contains 14 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 1 month ago.
