  • gibbs200 Friend
    #158264
    Hi guys,
    My first post here, so please be kind!
    I am using your JA Social template and have fully installed, I am currently setting up the modules etc..
    I am using Right, Main, Left setup. To display a module on the left hand side I have to set the module to ‘right’ and to display on the right I have to select ‘left’ module position. However, anything that I try to display in the right module position is displaying outside of the template. If I have nothing displaying in the ‘right’ module position then the template displays correctly with some modules (that I cannot find e.g. ‘search’ ‘new photo’s and ‘online users’ ) however as soon as I try to display a standard joomlart module that comes with the template it cuts this section off and displaying incorrectly.
    any ides how to fix this?
    aman204 Friend
    #370049
    Can you provide a link to your site
This topic contains 2 replies, has 2 voices, and was last updated by  aman204 14 years ago.
