  • passgold Friend
    #158589
    When using JCE Editor on the frontend with JA SOCIAL template,
    JA SOCIAL theme wipe out JCE Bouttons.. and i can see only a hml view of a textarea
    Please help
    PS:
    some errors from console:
    /joomla3//langs/en.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//themes/advanced/editor_template.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/contextmenu/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/inlinepopups/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/paste/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/help/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/advlink/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/advcode/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/xhtmlxtras/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/imgmanager/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/style/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/nonbreaking/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/searchreplace/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/article/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/fullscreen/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/visualchars/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/print/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/preview/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/spellchecker/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/advlist/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/code/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/format/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/cleanup/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/tabfocus/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3//plugins/wordcount/editor_plugin.jsFailed to load resource: the server responded with a status of 404 (Not Found)
    /joomla3/t3-assets/administrator/components/com_flexicontent/assets/images/error.pngFailed to load resource: the server responded with a status of 404 (Not Found)
    Hello
    You try to disable the Optimize JS function via the template’s configuration, and provide me the link to your site, i will check and resolve the issue
    jreimer Friend
    #376825
    That worked for me to disable the “optimize js function”
    Thanks!
This topic contains 3 replies, has 3 voices, and was last updated by  jreimer 13 years, 11 months ago.
