I am hoping someone can help me out with these two problems, as I’ve not seen them posted elsewhere.
Both of these occur in configuring JA Submit.
One: Even though I have many categories defined and published in the Category Manager, they don’t show up to select when configuring JA Submit. That pull-down is empty
Two: In the pull-down to select the default WYSIWYG editor, it is empty. Initially, I had TinyMCE defined as the default editor in the Global configuration. So I installed JCE and set that as the default (both of which worked in the front end). Still no choices to select a WYSIWYG.
Any help that you seasoned pros can provide will be greatly appreciated!
Thanks,
David
