June 29, 2016 at 2:33 am #945172Hi Artur,
Are you using the latest version of JA Social Feeds plugin?
June 29, 2016 at 6:08 am #945270Hi,
I think so. I’ve version 1.2.6.
Regards,
ArturSaguaros ModeratorSaguaros
June 30, 2016 at 2:38 am #945625Hi Artur,
Could you share me the Admin & FTP account of your site so I can have a look?
June 30, 2016 at 6:16 am #945692This reply has been marked as private.Saguaros ModeratorSaguaros
June 30, 2016 at 10:39 am #945772Hi Artur,
Could you specify images in which items that not look well?
June 30, 2016 at 6:17 pm #945876Hello,
For example in this first article system import very small image:
http://wwr.com.pl/facebook/1654-facebook-id-10154256367900762
which looks crappy on main site:
http://wwr.com.pl/
but on facebook this pic is in normal size:
https://www.facebook.com/wwrnews/?fref=nf
Is it now clear?
Regards,
ArturLuna Garden ModeratorLuna Garden
- July 2011
- 453 times in 425 posts
July 1, 2016 at 8:16 am #946003Hi,
I attach the package of this plugin here which includes the fix, you can install it and run the cron to import again.
If the 1st import doesn’t work, please try to clean all caches (or disable cache plugin) and import again.
July 4, 2016 at 7:30 am #946521Hi,
Unfortunatelly, there is no difference.
Regards,
- July 2011
July 4, 2016 at 10:32 am #946585Unfortunatelly, there is no difference.
Did you try to re-import with Update Article set to Yes, and remember to increase number import.
We can’t access to backend of your site, it getting error Class ‘FOF30ContainerContainer’ not found.
Once we can access it, we will try to help you check this problem.July 5, 2016 at 6:23 am #946856This reply has been marked as private.Luna Garden ModeratorLuna Garden
- July 2011
July 6, 2016 at 9:23 am #947246My bad, somehow I sent you the wrong package, I did update on your site. I’ll attach the new package.
Please check and confirm the result.
1 user says Thank You to Luna Garden for this useful post
This topic contains 12 replies, has 3 voices, and was last updated by artij 8 years, 4 months ago.
The topic ‘JA System Social Feed low quality images’ is closed to new replies.
