  • wbtnz Friend
    #120672
    Great Template. Thanks guys. 😀
    I need a little help wiht the ja-tabs module.
    In the ja-tabs I have a featured article but the read more link doesn’t go to the correct place.
    I am developing our new Teline based site in a sub folder called http://www.wycliffe.org.nz/new/ (and plan to make it live it in about 2 weeks.)
    But when I click the read more link in the featured article it goes to http://www.wycliffe.org.nz and not the /new/ article.
    Can anyone give me a clue where to start solving this problem?
    Thanks,
    Greg
    Khanh Le Moderator
    #221580
    Does the problem occur with other template? I think you should check your “Featured article” module to fix this problem.
    wbtnz Friend
    #222422
    <em>@Khanh Le 17461 wrote:</em><blockquote>Does the problem occur with other template? I think you should check your “Featured article” module to fix this problem.</blockquote>
    Sorry it took so long to get back here. I forgot to subscribe to this thread and have only got back here by searching. Bit of a noob …
    To answer your question:
    I only have one template on our site – JA Teline
    I have just changed the content item that it is featuring and the Read more… still goes to the wrong place??
    Any help would be appreciated.
    Thanks,
    Greg
    wbtnz Friend
    #222558
    Hi again,
    I have found a work around for this. Modified the featured article code.
    If anyone wants to know more let me know.
    Thanks to David Thomas for his help,
    Greg
    freissmann Developer
    #447767
    YES problem occures as well on other templates. From my point of view JA Tab Plugin is still buggy.
    There are as well other issues.
    CSS Style Error
    Javascript & Email
    Various other issues
    So far there are no sufficient solutions available – as well I did not find any alternativ extension…
    Any ideas?
This topic contains 5 replies, has 3 voices, and was last updated by  freissmann 12 years, 8 months ago.
