  • csizmadia csaba Friend
    #132229
    JA Tabs plugin installation problem
    I’ve downloaded ja tabs plugin for joomla 1.5.x but I could not install it. I use J! 1.5.5. Error massage is: Error! Could not find a Joomla! XML setup file in the package.
    Pls help, thx
    Menalto Friend
    #272529
    Did you sort this out yet? If you did please mark this as solved, if not justreply here and we will try to help you out as we can.
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 1 month ago.
