December 11, 2008 at 11:58 am #136153
1. When you publish a Module Type of mod_custom to JA Tabs (look at Calendar & Recent News tabs), the text does not wrap properly.
2. When you publish a Module Type of mod_custom to User 5 position, the text does not wrap properly and the Title is at far left of module.
3. I published the module of “Latest Posts” to User 5 and it has the same problems – Title is far left and content has no padding.
See:
http://www.alaskademo.com/This template has a lot of bugs and doesn’t seem like it was tested very thoroughly.
scotty Friendscotty
- March 2008
- 827 times in 595 posts
December 11, 2008 at 1:10 pm #2823461. Did you copy & paste from another web page? Each sentence is in a DIV and this is why the text is appearing like it is.
<div>Broadcasters are about to switch to transmitting solely
digital signals. Here’s the lowdown.
Prepare for the Switch</div> <div>Prepare for the
Switch</div> <div>Broadcasters are about to
switch to transmitting solely digital signals.
Here’s the lowdown. Prepare for the Switch</div>
<div>Prepare for the Switch</div> <div>
solely digital signals. Here’s the lowdown.
Prepare for the Switch</div>Open the module and remove these div”s and it should be fine.
2. This is a bug alright. JA have set a styling in mass-col (User5) to padding: 0 so that the tabs module displays correctly. This means though, that if you set a normal mod in that position it will have 0 padding. To fix this you can put a new suffix in your CSS and add that suffix to any normal mod you want in user 5. Open template.css and add the following AFTER the other module styling.
/* Mass Suffix */
div.module,
div.module_mass {
background: url(../images/bor_br.gif) no-repeat right bottom !important;
margin-bottom: 10px;
width: 100%;
float: left;
clear: both;
}div.module_mass div {
background: url(../images/bor_bl.gif) no-repeat left bottom;
margin: 0;
}div.module_mass div div {
background: url(../images/bor_tr.gif) no-repeat right top;
}div.module_mass div div div {
background: url(../images/bor_tl.gif) no-repeat left top;
padding: 0 10px 10px;
overflow: hidden;
display: block;
}div.module_mass div div div div {
background: none;
padding: 0;
display: block;
clear: both;
width: 100%;
Now open your modules published to user5 and in the ‘Module Suffix’ box enter _mass and save.This should sort it out.
December 11, 2008 at 9:02 pm #282430Scotty,
Thanks for helping. The first item has the problem not matter if the text is wrapped in divs or not. I first tried it by just adding text in the editor and it had the same problem. I tried wrapping it in divs to have better control. If I force a inline width setting, it will work.
It is a bug in the template I think.
I’ll try your recommendation for 2 but it seems like Joomlart should be fixing this don’t you think?
Thanks again.
scotty Friendscotty
- March 2008
December 11, 2008 at 9:36 pm #282437My fix for your second problem might help with the first one too. Also…
Open template.css (line 760)
div.module div div div div {
background:transparent none repeat scroll 0 0;
clear:both;
display:block;
padding:0;
width:100%;
…and change to…
clear:both;
display:block;
padding:0;
}Yes Joomlart should and do fix these problems. They can not check everything before a release and sometimes bugs can show up months after a release.
1 user says Thank You to scotty for this useful post
This topic contains 4 replies, has 2 voices, and was last updated by scotty 16 years ago.
