Viewing 11 posts - 16 through 26 (of 26 total)
  • rynek23 Friend
    #421543
    i send you by priv massage: backend access, do you want ftp access to?
    Yes thanks
    rynek23 Friend
    #421548
    if you need ftp, please write, but i install quickstart ja travel and dont change any file in http://ftp...
    Only one question
    why you are doing that with the plugin if you have the Ja_tabs module ? in the quickstart version there isn’t any module or article using the plugin in that way
    That configuration is used in Joomla 1.7 only because the J1.7 uses only the plugin
    rynek23 Friend
    #421568
    sow if ihave joomla 1.5 i cannt make this effect in article as is on ja travel typography ??? or i must use another way to make this effect??? in one article submenu to all article which ids i add there?
    Please read this guide for ja_travel 1.5
    rynek23 Friend
    #421582
    dear pavit
    i readthisbefore, now and istill dont know how i can make this kind of effect???
    please tell me beaceause now i dont know anythink…
    1. typo-tabs
    Hi rynek23
    I have created a new menu item “Prova” in your main menu, now is unpublished i have tested it and the plugin works correctly
    can you check ?
    jooservices Friend
    #421640
    Hi rynek23,
    [PHP]
    Internal Server Error
    The server encountered an internal error or misconfiguration and was unable to complete your request.
    Please contact the server administrator, webmaster@polskikolagen.pl and inform them of the time the error occurred, and anything you might have done that may have caused the error.
    More information about this error may be available in the server error log.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    Apache/2 Server at polskikolagen.pl Port 80
    [/PHP]
    this error come when you access http://polskikolagen.pl/component/content/article/42-o-kolagenie/101-czeste-pytania-dot-kolagenu.html
    because please take a look in your code
    [PHP]{jatabs type=”articles” ids=”99, 100, 101″ ajax=true view=”introtext” position=”left” widthTabs=223 width=880 animType=”animMoveVir” pre=true}{/jatabs}[/PHP]
    Your Ja tabs article id is 101 , in the code you could not put the 101 into.
    I removed it and now it work fine.
    Please check again.
    Viet Vu.
    rynek23 Friend
    #421711
    yes you have right… it was sow simple 🙂 i add to code ids article where this code was added…
    :you have thanks for me
    jooservices Friend
    #421806
    You’re welcome. It seems your problem was solved. :laugh:
    Viet Vu,
This topic contains 26 replies, has 3 voices, and was last updated by  jooservices 13 years, 1 month ago.
