  • FelixJoomlArt Friend
    #164616
    Teline IV, Joomla 1.6.3, latest T3 and JA Tabs.
    When I try to create JA Tabs from modules (according to template manual and help) with setting the position ja-tabs1 or ja-tabs2 position for the module (even with or without the class -tab, -tabs) – I am not succesful. With manual creation {jatabs type=”modules” module=”mega5″… is it OK, but normal way not.
    On the same server on TelineIV demo is it OK – I put whatever on position ja-tabs1 and on frontpage is this on its place. (but the demo runs Joomla 1.6.0)
    Is there a way how to solve this?
    mayuri_g Friend
    #394013
    hello, you can display the modules in the tab by using the following setps:
    1) create different modules that you want to display in tab as mod_1, mod_2, mod_3, mod_4, mod_5.
    2) create a new module that will show the tab , in that module you can use the following code
    {jatabs type=”module” modulename=”mod_1, mod_2, mod_3, mod_4, mod_5″
    position=”left” animType=”animMoveVir” pre=true}
    {/jatabs}
    3) then give position to tab module and that will dispaly tabs.
    4) Note: All modules should be published.
    for help you can refer to the link http://demo.joomlart.com/extensions15/index.php?option=com_content&view=article&id=109
This topic contains 2 replies, has 2 voices, and was last updated by  mayuri_g 13 years, 5 months ago.
