test melih
 melih
  • splifen Friend
    #142018
    i’am having problems with http://icetech.centex.dk/index.php?option=com_content&view=article&id=240&Itemid=247&lang=da when viewing in mozilla firefox. is there anyon the have a solution….
    Regards Kenneth
    ps5t0ck5 Friend
    #308463
    Hi splifen
    I’ve had a look and it almost looks like the space available is not wide enough for the tab titles and they are not wrapping – as a quick test to see if this is the case try making one of the tab titles shorter.
    ps5t0ck5 Friend
    #308614
    This link might also be of interest – making the template width fluid.
    http://www.joomlart.com/forums/topic/how-to-make-ja-templates-to-fluid-width/
    Or you could just increase the width of that particular section, worth a thought.
    http://www.joomlart.com/forums/topic/frontpage-article-display/
    splifen Friend
    #308822
    sorry for the late reply, i’ve been out of town. I will test it tonight.
    You can see the problem more clearly here, if you change tabs
    http://icetech.centex.dk/index.php?option=com_content&view=article&id=197&Itemid=222&lang=en
    ps5t0ck5 Friend
    #308863
    Ok, for the second link this is what I see in Firefox
    All of the tabs are visible, work when clicked on – they aren’t in the same style as those in the demo template, intentional? There is no information in the Application or References (refrence typo?) tabs?
    This is the same as what I see in IE7.
    For your first link this is what I see in Firefox
    Three tabs are visible, one is beneath the rest and not properly visible, they do not work when clicked on and are ‘stuck’ on tab 1 – only tab 1 content shows as a result of previous point, they aren’t in the same style as those in the demo template, intentional?
    This is what I see in IE7
    All of the tabs are visible, work when clicked on – content shows according to tab selected, they aren’t in the same style as those in the demo template.
    The tabs not working in Firefox may well be resolved by applying previous posts.
    If it is the style thats an issue I would double check that you have selected the style you want. I don’t have this template installed anywhere at the moment but have experience with tabs. Not sure but it might make a difference according to whether you are using the plug-in or the module?
This topic contains 5 replies, has 2 voices, and was last updated by  ps5t0ck5 15 years, 7 months ago.
