  • macdok Friend
    #134695
    When placing the code for JA Tabs in an article the code shows up on the website. I’ve seen a number of posts on this but not one clear response. Please help.
    Joomla 1.57
    JA Kulanite Quick Start
    The code:
    {jatabs type=”content” animType=”animNone” style=”kulanite” position=”top” widthTabs=”120″ heightTabs=”60″ width=”600″ height=”200″ mouseType=”click” duration=”1000″ }
    When I change the articles the result on the site does change but the code remains.
    Here is the site: http://75.125.62.14/~southe55/
    Thank you,
    Kevin
    cpsucsa Friend
    #276832
    I have the same issue. I just layed down over AU$100 for the extensions access because I need JA-Tabs to work in a Joomla 1.0.x site. The lack of responses here in the forum is pretty appalling… 🙁
    mauney Friend
    #276970
    I am using JAPyrite template and try to install jatabs module and plugin as per manual jatabs manual for joomla 1.5.x. If I select tab style is content, all I get on the screen is
    {jatabs type=”content” animType=”animNone” style=”” position=”top” widthTabs=”120″ heightTabs=”30″ width=”100%” height=”auto” mouseType=”click” duration=”1000″ }This is tab content 1 This is tab content 2 This is tab content 3 This is tab content 4{/jatabs}
    If I change to tab style is module I got
    It is missing something that I don’t know. Please tell me what’s wrong.
    sdff Friend
    #277663
    Same thing here, just the text/code, no tabs.
    Anonymous Moderator
    #278042
    <em>@macdok 87538 wrote:</em><blockquote>Hello,
    Joomla 1.57
    The code:
    Thank you,
    Kevin</blockquote>
    Dear macdok,
    we had fixed this issue.
    you can fix this issue on your website by:
    + Download new vesion of JA Tabs at link: http://www.joomlart.com/addons/components_and_modules/ja_tabs.html. In administrator, go to Plugin Manager to uninstall old JA Tabs for Joomla! 1.5.Then you install new JA tabs vesion again. After install that, you go to front end to check.
    + Download new JA Kulanite template by link http://www.joomlart.com/templates_club/club_portfolio/ja_kulanite.html, then setup again
    Thanks.
    jagdishis Friend
    #278043
    Please verify this on http://www.devinspire.com
    The ja tabs dows not show up, even after publishing 2 modules correctly in user6 position
    jagdishis Friend
    #279107
    Thanks to joomlart.com team,
    ja-tabs is now working perfectly on http://www.devInspire.com. They have resolved the problem in a day.
    Cám ơn anh 🙂
    deem Friend
    #286980
    Hey,
    I have the same problem with ja-labra template..
    xaome Friend
    #294084
    same problem with JA Uvite template…
    Anonymous Moderator
    #294944
    hi,
    If you have a problem with ja tabs, please send me your live url, admin account, if possible, ftp account via PM so that i could find to fix this issue to help you.
    siriusthestar Friend
    #304243
    hi
    I have a question..I have a joomla 1.5.10 with JA Teline II template and have a problem with user6 position.
    An userguide says that it is enough to publish desired modules in that user6 position, but nothing shows in that place except one line about 10 high (as a module place).
    ..and Ja Tabs supposed to be integradted in JA Teline II? There is no such plugin in plugin manager
    gizzward Friend
    #312552
    <em>@siriusthestar 128130 wrote:</em><blockquote>hi
    ..and Ja Tabs supposed to be integradted in JA Teline II? There is no such plugin in plugin manager</blockquote>
    I have the same issue with JA Teline II, but the JA Tabs plugin worked perfectly for months, then it disappeared. I do not know if this means it might be a server issue. Were you able to solve this with JA Teline II?
    In addition, the pages appear to never finish loading now. I do not know if that is related. I do have rss feeds (if that matters), but they seemed to cause no problem before.
    gizzward Friend
    #312595
    It appears to be a browser issue. It works in Konqueror, but not in Firefox. I guess I have to upgrade Firefox.
    This appears to be solved.
    thumbelulu Friend
    #317881
    Can someone please tell me how to get the typography to work in JA Pyrite? When I switched editors, the fancy typography that JA Pyrite uses has disappeared…How do I get that back? Thank you
This topic contains 14 replies, has 11 voices, and was last updated by  thumbelulu 15 years, 3 months ago.
