  • exploreyourtrail Friend
    #158112
    I really like the JA Teline IV template but after installing the QuickStart and then adding the latest version of Jomsocial 2.04 I find that none of the dropdown menus work in Jomsocial 2.04 in the Blueface template, but they do work in the default template.
    The template menus (set to megamenu) but all the Jomsocial menus do not work at all in the blueface setting. If I switch to the default JS template the menus work. ????? Now sure why????
    Is there a fix to get the JS menus in Blueface Layout to work or do I have to yet once again use the default layout in Jomsocial? I have searched for s solution on the Jomsocial forums and also here on the JA forms and hope this can be fixed.
    RandyMac
    #369797
    Dear exploreyoutrail,
    It is better if you can post your site url here. It would then be easier for us to check and help you out.
    coalition Friend
    #370892
    I also have the same problem! :-[
This topic contains 3 replies, has 3 voices, and was last updated by  coalition 14 years ago.
