Viewing 15 posts - 1 through 15 (of 18 total)
  • prideofpakistan Friend
    #167209
    We are having problem on the Internet Explorer 8. The site works fine without any problems on the Latest browsers, like IE9, FireFox and chrome but on IE8 the layout breaks. I am attaching the screenshots kindly help us and let us know how to fix this issue.
    You can check the site on this link…
    http://www.prideofpakistan.com/v2/index.php
    And here is how the site appears on the IE8.
    jooservices Friend
    #405055
    Hi there,
    I’ve just checked your site and confirmed this bug. I’ll pass this trouble to dev team for checking.
    Will update news asap for you.
    Thank you
    Viet Vu
    #406215
    Can somone please help me out here ???
    This is a big issue for us… which must be resolved. Please suggest a fix for this.
    Thanks,
    Manos Moderator
    #406218
    Which version of ja newspro are you using ?
    Manos
    #406257
    <em>@pascm 259723 wrote:</em><blockquote>Hi,
    Manos</blockquote>
    I am using version 1.0.3 which came default with Teline IV…
    #406457
    Is there an update available to it ?? wht should i do to fix it ?
    joomlachile Friend
    #406740
    I had the same problem with IE8, I solve with this http://www.joomlacsszengarden.com/demo/index.php?option=com_remository&Itemid=7&func=fileinfo&id=42
    But the problem continues to IE7
    Any suggestions?
    Thank
    Manos Moderator
    #406741
    HI,
    It looks like a mootols issue, i will try to investigate this.
    Manos
    joomlachile Friend
    #406951
    <em>@pascm 260384 wrote:</em><blockquote>HI,
    Manos</blockquote>
    Any suggestions?
    Thank
    Manos Moderator
    #406953
    HI,
    Please try to update module, i suggest you use JAect manager to do this! (it’s installed if you have deploy quickstart).
    I hope that helps.
    Manos
    enbaron Friend
    #407692
    hi, how you solved your problem of compatibility of your site Teline 4with explorer? I also use 4 to drape a newspaper online Italian (Lombardy) but with explorer 8 not seen (http://www.leccoprovincia.it )
    have used some module? greet thanks
    Baroncelli
    direttore@leccoprovincia.it
    carmila Friend
    #417555
    I’ve the same problem with IE7. :-[
    I’m using the last version of Ja News Frontpage (1.4.0) and Ja Teline IV
    No problem with IE8
    Any Suggestions?
    Thanks for help
    Manos Moderator
    #417567
    <em>@enbaron 261593 wrote:</em><blockquote>hi, how you solved your problem of compatibility of your site Teline 4with explorer? I also use 4 to drape a newspaper online Italian (Lombardy) but with explorer 8 not seen (http://www.leccoprovincia.it )
    Baroncelli
    direttore@leccoprovincia.it</blockquote>
    Hi, it looks like you are using a different template on your site.
    Manos
    Manos Moderator
    #417568
    <em>@carmila 273791 wrote:</em><blockquote>I’ve the same problem with IE7. :-[
    No problem with IE8
    Any Suggestions?
    Thanks for help</blockquote>
    Can you please show us your website so we can see the problem and help you?
    Manos
    carmila Friend
    #417573
    I send you a PM
    This is the screen
    1. error-page
This topic contains 18 replies, has 6 voices, and was last updated by  Manos 13 years, 3 months ago.
