  • pitkag Friend
    #194440
    I am using ja-news pro in my template Ja-Teline IV. I am creating separate modules but using the same default profile
    When i use the profile in a new module it overwrites the previous module, Like if use 2 columns in one module and i use 3 columns in the next module, it overwrites the changes on the first module. Where could the problem be?:((
    Manos Moderator
    #521005
    You need to clone the profile in order to use is again with different settings.
    Manos
    pitkag Friend
    #521006
    Thanks very much, It works perfectly 🙂
    Manos Moderator
    #521007
    Glad to hear that! Marked this as solved!
This topic contains 4 replies, has 2 voices, and was last updated by  Manos 10 years, 11 months ago.
