  • imamrevista Friend
    #173772
    My site is all messed up in IE7, follow the link: http://www.imam.com.br
    Regards,
    Imamrevista
    1. imamprob
    imamrevista Friend
    #438214
    Someone help me?
    John Wesley Brett Moderator
    #438339
    You apparently are copying and pasting from MicroSoft Word or some other similar program – without first stripping out the code!
    This is a MAJOR no-no for Joomla…and can lead to these and all sorts of other problems in outdated Internet Explorer browsers (pre IE8).
    You need to clean up your content, both copy and images.
    A few areas of immediate concern are:
    A. Your images are being squeezed in the frame. Your image settings are wrong.
    B. This combination of Non-Teline set Font with link attached is obviously not entered directly into your Teline template.
    C. The fonts are totally different in these consecutive stories.
    These are just three areas that are immediately apparent. There are others, but I believe you see what needs to be done.
    Bottom line…you’ve got a content mess and that is what is breaking your IE7.
    Modern browsers are more forgiving when it comes to code irregularities, but IE seems to thrive on throwing them up. 🙂
    Have fun!
    John.
    1. IE7error
This topic contains 3 replies, has 2 voices, and was last updated by  John Wesley Brett 12 years, 11 months ago.
