December 12, 2011 at 3:03 pm #171733
I have this problem only with IE8 (see picture), with Chrome and Firefox works fine. Today I updated components, modules and plugins to the latest version, but nothing has changed. I work in Joomla 1.7.2. How can I fix this?
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
December 13, 2011 at 9:27 pm #429528Hi,
This one looks like a non closing div so please check if you have any article that has a non closing div or if you have pasted some text from word check to see if there is unwanted code in it.
1 user says Thank You to Manos for this useful post
dieudonne Frienddieudonne
- January 2011
- 107 times in 3 posts
December 13, 2011 at 9:40 pm #429530Hello,
because the title of this post is : JA Teline IV serious problem with IE8, here is a post with no solution yet.
Can we have some helps ?
Thank in advance.1) http://www.joomlart.com/forums/topic/ie8-border-problem-with-ja-thumbnail-top-border-too-low/
December 14, 2011 at 5:38 am #429554Ok! I will try in the afternoon. Thanks for the answer
- February 2014
December 29, 2011 at 2:44 pm #431760I have not solved.In compatibility mode in IE8 works.
Thanks AnywayManos ModeratorManos
- February 2014
February 1, 2012 at 10:18 am #436452Changed templates. Now function.
thanksManos ModeratorManos
- February 2014
February 8, 2012 at 7:24 pm #437596Hi,
You mean you upgraded to the latest version or you use an other template now ?.
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by Manos 12 years, 11 months ago.
