August 23, 2012 at 11:01 am #180165
I want to put translated menu items in Top Mega menu at right hand side.
I was able to translate Main Menu without any issues.
But I am not able publish English version of menu in right side of menu .I have created topmega for Spanish.and topmega_en for English.
topmega_en is not showing up in English.
Site en Url :http://navegalo.co/index.php?lang=en
Site es Url: http://navegalo.co/index.php?lang=es
Any ideas ?
Regards,
AbhijitNinja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
August 25, 2012 at 3:33 am #465289Your site is working now with both language. Kindly check again and if you have further issue please don’t hesitate contact to us.
August 26, 2012 at 5:34 am #465359<em>@Ninja Lead 335836 wrote:</em><blockquote>Your site is working now with both language. Kindly check again and if you have further issue please don’t hesitate contact to us.</blockquote>
Site was working in both languages.
Issue is the icons menu which is located in top mega.
I want to convert few of them in TEXT based menu.
I cant translate that menu.Only one shows up which is named as “topmega”(menuname) in Mega Menu .
Template doesnt show topmega-en which is translated menu in english.
Regards,
- November 2014
August 27, 2012 at 8:25 am #465444Firstly: You need to work at local and test carefully before applying for live site
You change it from image to text by css file
Open templates/ja_teline_iv/css/template.css
from
#ja-topmega li.nav-blog a.nav-blog,
#ja-topmega li.nav-interview a.nav-interview,
#ja-topmega li.nav-social a.nav-social,
#ja-topmega li.nav-feeds a.nav-feeds {
padding: 4px 0 3px;
margin: 3px 5px;
text-indent: -1000em;
width: 28px;
}change to
padding: 4px 0 3px;
margin: 3px 5px;
color: #333
border: solid 1px blue;
text-transform: none;
}and remove all
/* Blog Button */
#ja-topmega li.nav-blog { background: url(../images/stripe-bg-2.png); }#ja-topmega li.nav-blog a.nav-blog {
background: url(../images/icons/nav-blog.png) no-repeat center #000 !important;
}#ja-topmega li:hover a.nav-blog,
#ja-topmega li.over a.nav-blog,
#ja-topmega li.active a.nav-blog {
background: url(../images/icons/nav-blog.png) no-repeat center #3b7513 !important;
}#ja-topmega li.nav-blog .ja-moduletable ul li {
padding-left: 10px;
}#ja-topmega li.nav-blog .childcontent-inner {
background-image: none !important;
}#ja-topmega li.nav-blog .ja-moduletable .k2LatestCommentsBlock ul li {
background: none;
padding-left: 0;
padding-right: 0;
}/* Interview Button */
#ja-topmega li.nav-interview { background: url(../images/stripe-bg-2.png); }#ja-topmega li.nav-interview a.nav-interview {
background: url(../images/icons/nav-interview.png) no-repeat center #000 !important;
}#ja-topmega li:hover a.nav-interview,
#ja-topmega li.over a.nav-interview,
#ja-topmega li.active a.nav-interview {
background: url(../images/icons/nav-interview.png) no-repeat center #e04b40 !important;
}#ja-topmega li.nav-interview .childcontent-inner {
}/* Social Button */
#ja-topmega li.nav-social a.nav-social {
background: url(../images/icon-twitter.png) no-repeat center #138bb3 !important;
}#ja-topmega li:hover a.nav-social,
#ja-topmega li.over a.nav-social,
#ja-topmega li.active a.nav-social {
}/* RSS Feeds */
background: url(../images/icon-feeds.png) no-repeat center #f68916 !important;
}#ja-topmega li:hover a.nav-feeds,
#ja-topmega li.over a.nav-feeds,
#ja-topmega li.active a.nav-feeds {
background: url(../images/icon-feeds.png) no-repeat center #F68916 !important;
}#ja-topmega li.nav-feeds .childcontent-inner { background: #fff padding-top: 0;}
/* Ja Twitter Modules ---*/
div.ja-twitter { font-family: Arial, Helvetica, sans-serif; font-size: 11px; padding: 0; }.ja-twitter-wrapper ul li { background: none; }
.ja-twitter-wrapper {
background: #f0f0f0
border: 1px solid #ccc
margin-bottom: 10px;
padding: 8px;
}.ja-twitter-wrapper .ja-twitter-avatar { padding-right: 2px !important; }
.ja-twitter-image { display: block; float: left; }
.ja-twitter-source,
.ja-twitter-text { color: #333 }.ja-twitter center img { float: none !important; }
.ja-twitter h4 { margin: 10px 0; padding: 5px 0; }
<blockquote>Go to Admin area-> Menus-> duplicate topmega and assign it with each language </blockquote>
August 27, 2012 at 1:41 pm #465485<em>@Ninja Lead 336048 wrote:</em><blockquote>Firstly: You need to work at local and test carefully before applying for live site
from
padding: 4px 0 3px;
margin: 3px 5px;
width: 28px;
}change to
padding: 4px 0 3px;
margin: 3px 5px;
color: #333
}and remove all
/* Blog Button */
padding-left: 10px;
background: none;
padding-left: 0;
padding-right: 0;
}/* RSS Feeds */
background: #f0f0f0
padding: 8px;
.ja-twitter-source,
</blockquote>
For First part I had created a new class and applied to each menu item using JA Extendend Parameter.So no worries with CSS.Second Part ..Duplicating Topmega to Tomega-en didnt work ..Tried to modify topmega.php in blocks using get language joomla functions…that failed…:((
Then I just duplicated menu items to English menu items and Spanish menu items.That did the trick..Worked…:):)
Thanks a lot for your help.
Regards,
AbhijitJanuary 5, 2013 at 7:23 am #478495Hello,
I saw your response to the JA Teline IV topmega menu(social icons+text at right hand side) Language issue in the forum on 25th August2012 and was wondering if you could help me,
I would like to put the social icons (Twitter, Facbook, etc) on the right hand side of the JA Teline IV topmega menu block (i.e. to the
right of my main menu items): http://www.ghanaoracle.com/testCan you help?
I look forward to hearing back from you.
Joyce Sarpong
- November 2014
January 10, 2013 at 10:45 am #479248Regarding to social icons+text at the right hand side on your site you can make to create a module and assign it with mega position.
If you would like to make multilaguage on this you can duplicate module: a module assign with EN language and a module assign with another language.
February 7, 2013 at 10:04 pm #482825<em>@Ninja Lead 354507 wrote:</em><blockquote>Regarding to social icons+text at the right hand side on your site you can make to create a module and assign it with mega position.
If you would like to make multilaguage on this you can duplicate module: a module assign with EN language and a module assign with another language.</blockquote>
Thank you for your response.
February 7, 2013 at 10:11 pm #482826Hello Abhijit,
I am developing my website using JA Teline IV and Joomla 2.5. I have looked at your Navegalo website and seen that you have an RSS feed to produce news articles for your site. Can you tell me which RSS feed extension you used?
Kind regards,
Joyce
February 7, 2013 at 10:22 pm #482827Hello Abhijit,
I am developing my Joomla site using Joomla 2.5 and JA Teline IV. My site is an online magazine and as such, I would like to use
an RSS feed to automatically feed news articles to my site. I have seen that you do something similar on your Navegalo site. Can
you please tell me what extension you use?Many thanks,
Joyce
- November 2014
February 8, 2013 at 3:16 am #482841Did you try JED or you can use Feed Gator .
February 8, 2013 at 10:01 pm #482910Hello,
I have installed Feed Gator on my website (http://www.ghanaoracle.com/test) and I am trying to modify the settings to how I would like the feeds to be displayed. I have some issues / queries. E.g.
1. When I click on the READ MORE, I would like the full article / txt to be displayed.
2. I would like the logo that’s associated with the source RSS feed to be displayed when the feed is imported.
3. I would like the RSS Feed to be collected in real time.Many thanks,
Joyce.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
February 8, 2013 at 10:31 pm #482913Configuration of feedgator is something you need to aske the feedgator team how to accomplish. It is all quite simple but there are a lot of things that need to be adjusted depending on how the original feed is setup. As for adding a logo, that is something that is often asked of the feedgator team and something they have been promising for a while. Hopefully they will add that feature soon.
February 9, 2013 at 6:30 am #482919Hello Phill,
Thanks for your response.
Please can you give me details (i.e. URL, email etc) of how to get in touch with the
Feedgator team?
U
Many thanks.Phill ModeratorPhill
- February 2014
February 9, 2013 at 10:49 am #482928The feedgator support forums can be found here – http://joomlacode.org/gf/project/feedgator/forum/
This topic contains 16 replies, has 4 voices, and was last updated by joycesarpong 11 years, 11 months ago.
