asifak Friend
asifak
- November 2010
- 2 times in 1 posts
August 19, 2011 at 12:33 pm #167581JA Telline III V2
I am trying to configure a ‘Login’ menu in the main menu of the JA Telline IIIV2 template. I want to use ‘Parameters JA-Extended’ to show the CBLogin module (Login module from community builder). However, the menu does not appear at all . Here is the procedure adopted;1) Created mod_CB-login module with the name ‘Login2’, with a new position called ‘log’
2) Then I created the Login menu with menu type of ‘separator’
3) Then I selected the module position Parameters JA-Extended’ and selected the ‘log’
Infact I have tried many possibilities , and have wasted all day trying to configure it but it does not work.
asifak Friendasifak
- November 2010
August 19, 2011 at 1:06 pm #407079I am using ‘Drop Line’ menu type, will it work ??
asifak Friendasifak
- November 2010
August 20, 2011 at 4:42 am #407200Infact megamenu configured in demo version never worked on my website. Demo version consist of ‘member’ and ‘Twitter’ menus on top bar, which never appears in my case. Is this problem also due to Mootools. I am already facing ??
Manos ModeratorManos
- February 2014
- 633 times in 576 posts
August 27, 2011 at 8:16 am #408908<em>@asifak 260823 wrote:</em><blockquote>I am using ‘Drop Line’ menu type, will it work ??</blockquote>
Hi asifak, if i understand well what you want to achieve, you need mega menu style to make it work.
As far as i know this issue is not related with Mootools issue.
Manos
asifak Friendasifak
- November 2010
August 28, 2011 at 5:27 am #409075so what is the solution then ..
n6rej Friendn6rej
- November 2006
- 145 times in 90 posts
August 28, 2011 at 5:45 am #409077your on the right track.. look @ http://hallhome.us if the login in the nav bar is what you want.. then go to the menu go to extended parameters on the right, select “module” and then select the login module. viola
1 user says Thank You to n6rej for this useful post
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
August 28, 2011 at 7:30 am #409096asifak:
Depending on your envisioned final solution, perhaps this will further assist you . . . . .
How To Assign Modules Into MegaMenu (JAT3 2.0)
MAD PROPS to JA Support Team Member n6rej (aka:”Bear”) 😎
n6rej Friendn6rej
- November 2006
August 28, 2011 at 4:04 pm #409171thanks bud, de natha
asifak Friendasifak
- November 2010
August 29, 2011 at 7:40 am #409341Hi TomC,
The video shows standard Megamenu, I have already done this. It is achievable. However, this is not what I want. I want a menu bar on the Top bar (the same bar where date / time are displayed). Now, on the right corner of this bar I am interested to place CB Login and search menu. I tried many many options but could not make this.
a Login menu should be there and when mouse is hovered on this then Login module appears where user can enter. -
This topic contains 9 replies, has 4 voices, and was last updated by asifak 13 years, 4 months ago.
