Viewing 15 posts - 1 through 15 (of 37 total)
  • asifak Friend
    #166135
    I am using Ja Telline IIIV2:
    Ja-popup plugin works well when used in a JA-Tabs and will show videos from youtube. However, when following code is used in a article, which works well in JA-Tabs, then whole template is disturbed such as JA-News2 and JA-Tabs shifts much to down (altogether frame / template broken)
    Following code :
    {japopup type=”youtube” content=”http://www.youtube.com/v/GVouSi0cY1U?hl=en&fs=1″ width=”750″ height=”440″ title=”Stages Of Pipeline Construction “}<img src=”http://img.youtube.com/vi/GVouSi0cY1U/2.jpg” border=”0″ alt=”Stages Of Pipeline Construction ” />{/japopup}
    himangi Friend
    #401135
    Hi asifak,
    Sorry for the late reply!
    Can you please provide your site url and admin access at http://support.joomlart.com/index.php?/Tickets/Ticket/View/76217 I will take a look at the issue.. On the link I have given, you need to login with your JA username and password.
    asifak Friend
    #401157
    Well, Thanks!
    My site information is already with Joomlart and they are working on the issue http://www.joomlart.com/forums/topic/ja-telline-iiiv2-module-disruption-of-ja-news2-and-ja-tabs/. nguoiabcd‘ from Joomlart is coordinating to resolve this issue.
    [/B]
    himangi Friend
    #401158
    I dont see the details on the ticket link i had provided.. Can you please give me the site admin details there, so that I can check the issue?
    asifak Friend
    #401186
    I have updated the ticket with necessary username and passwords
    asifak Friend
    #401187
    Did you notice in another thread ‘Column Glitch?’
    It is posted recently, and the result of this problem is same as I have reported for the JA Popup Plugin.
    Seems to be a common issue of articles ..
    himangi Friend
    #401260
    I see everything is working fine when the particular video you have mentioned above, is being displayed.. JAnews2 and other JA tabs module than the Videos tabs, are exactly where they are published. I have attached a screenshot for your reference.
    1. homepage
    asifak Friend
    #401288
    Well thats not true !!
    Did you try above script I have given in my earlier post of this thread. I think When you opened the webpage there was no script.
    Now I inserted ja-popup script in Article No. 13 under the Article manager. Now what happens is described here step by step.
    1) When you open webpage first time then the problem occurs. The result is shown in the attachment. Even the JA-Tabs has disappeared. (In such case other problem which I have stated in other thread ‘JA telline IIIV2: Module disruption of JA News2 and Ja Tabs‘ does not happen)
    2) I have set system cache plugin to 5 minutes. Within 5 minutes when you refresh the page again , then this japopup plugin problem will disappear and other problem ‘JA telline IIIV2: Module disruption of JA News2 and Ja Tabs‘ will appear.
    In summary, both of these problems occur alternatively. By the way, article which I am using for testing of this is ‘System tech new’. You can read it in the ‘JA-News2 under the ‘system’ categories.
    Interesting right !!! (it looks I am testing engineer for joomlart. Joomlart should pay to me !!!)>:(:-*
    1. JA-plugin-problem
    himangi Friend
    #401297
    I am sorry, I am not sure what is happening. I compared your video popup syntax with the syntax specified in demo, and I dont see any difference. Can you please tell me what was the syntax you were using when I checked the site and it was working correctly?
    Also after loading site for the first time, I saw the same page as the screenshot you have provided but after refreshing the page, nothing changed.. I am seeing the same page..
    Can you please tell me what the difference is in the code, then I can investigate again. Fyi I havent come across this problem before, and everything has been working fine with the popup videos..
    asifak Friend
    #401330
    I informed earlier that perhaps when you browsed the web page first time to see then there was no script thats why you did not find any problem. I am using the same code as provided in my earlier post and it is same as demo. It is again here for your reference.
    By the way I have deleted this ja-popup script from the article No. 13 othewise it will confuse the people who are working to resolve the other issue raised by me in other thread (‘JA telline IIIV2: Module disruption of JA News2 and Ja Tabs‘ ). If you want to see again then I would request that please login, put the ja-popup script there and test it and delete this afterwards.
    One more thing, as I described in my earlier post of this thread, this thread and (‘JA telline IIIV2: Module disruption of JA News2 and Ja Tabs‘ ) may have something common issue.
    cheers!
    himangi Friend
    #401380
    Hi asifak,
    The {japopup ….. }{/japopup} code you have placed in the module is the only code you need to use to have the popup functionality as per my knowledge. Everything else is taken care by the JA Popup plugin which you have installed and enabled.
    I am referring to http://demo.joomlart.com/extensions15/index.php?option=com_content&view=article&id=162&Itemid=137 and it doesnt tell you add any popup script separately with the syntax for displaying popup images / videos, so i am not sure which script you are referring to.. Please clarify.
    asifak Friend
    #401400
    ok, lets put it other way. I want to popup a video in a article. My steps are:
    1) Open Article manager and relevant article.
    2) Toggle editor
    3 paste the whole following script at the required place within the article
    Now, please inform whether above steps and script are ok. Have you login into my site ? Can you please do it for one of my articles.
    Thanks!
    himangi Friend
    #401402
    Ok I was getting confused due to the word ‘script’ 🙂 I will take a look at it but can you provide the superadmin access instead of admin access. It will be easy to investigate if I can check versions of extensions and change templates to see what happens with the JA Tabs module with various settings.
    asifak Friend
    #401418
    You got the ftp login, please use that..thanks1
    himangi Friend
    #401421
    Hi Asifak,
    Yes I have the ftp access but I need superadmin access to joomla backend. The current access you have provided is an admin access which does not allow me to check the version of the JA popup plugin and reinstall it if required, without that access I can only play with the module which is not of any help at this point. Kindly provide the superadmin access so that I can check the issue.
This topic contains 37 replies, has 6 voices, and was last updated by  Blaine 13 years, 3 months ago.
